Informácie obiashnuté vo VIN čísle
Re: Informácie obiashnuté vo VIN čísle
Příspěvek od Phrz »
jojo bude trosku vic priskrcenej aby splnil euro 6 :D
richkr74
Příspěvek od richkr74 »
Zdravim ,mohol by mi niekto dekodovat toto VIN? W0LPE6EC0E1106602. Niekedy davno to tu niekto robil,dekodovali mi tu Zafiru B ale na vedlajsom fore Astra H - Zafira B forum. Viete to urobit aj z Astrou J 103kw 1.4 . Dakujem
Xzar
Příspěvek od Xzar »
Code = Description
*** General information: ***
AUY = BREAKPOINT IDENT CONTROL
AXJ = VEHICLE TYPE, PASSENGER CAR
CR7 = FOR HUNGARY
FPV = BREAKPOINT IDENT CONTROL
GAR = EXTERIOR PAINT, SEE MODEL CATALOGUE FOREWORD PAINT CHART
PE = EQUIPMENT LEVEL: COSMO / INNOVATION
V83 = VEHICLE STATEMENT - ECE ORGANIZATION
VD1 = EUROPE EQUIPMENT
VRH = OPEL / VAUXHALL SPECIFICATION - STEERING COLUMN
XL8 = FOR 433 MHZ FREQUENCY
ZP5 = SEATING ARRANGEMENT 5 PASSENGERS
*** Drive (engine, transmission): ***
F82 = FINAL DRIVE RATIO 3.23
LUJ = A14NET[LUJ] PETROL ENGINE
MH8 = 6T40 AUTOMATIC TRANSMISSION
MM1 = USED WITH AUTOMATIC TRANSMISSION
NE9 = EMISSION SYSTEM EEC 09
V48 = COOLANT,MAXIMUM PROTECTION
*** Suspension and wheels: ***
GNA = CHASSIS EQUIPMENT, FRONT STRUT ASSEMBLY
GNG = REAR AXLE, TORSION BEAM AND WATT LINKAGE
PXS = WHEEL,ALUMINUM,17 X 7J
QAJ = TYRES,215/50R17-91V
RU5 = FOR SPACE SAVER WHEEL
VRL = OPEL / VAUXHALL SPECIFICATION - FRONT HORIZONTIAL SUSPENSION
VRM = OPEL / VAUXHALL SPECIFICATION - FRONT VERTICAL SUSPENSION
VRN = OPEL / VAUXHALL SPECIFICATION - REAR SUSPENSION
VRR = OPEL / VAUXHALL SPECIFICATION - TYRES AND WHEELS
*** Glass and mirrors: ***
AEF = POWER WINDOWS, EXPRESS UP/DOWN
AER = ELECTRICALLY OPERATED WINDOWS,REAR
AKN = GLASS,TINTED
AKW = WINDSCREEN,TINTED
AXG = FOR ONE TOUCH WINDOW
C25 = TAIL GATE WIPER AND WASHER
D6I = VISOR,SUN,WITH ILLUMINATED MIRROR
DD8 = FOR LIGHT SENSITIVE INTERIOR MIRROR
DP6 = MIRROR HOUSING, PAINTED
DWE = USED WITH MANUAL FOLDING MIRROR
*** Lighting: ***
C95 = LAMP,ASSY,ROOF,WITH DUAL READING LAMP
C9B = LAMP INTERIOR, AMBIENT, DOOR
C9D = LAMP INTERIOR, AMBIENT, CONSOLE
CE4 = HEADLAMP WASHER
T39 = LAMPS,TURN SIGNAL,AUXILARY
T3N = FOR DAYTIME RUNNING LAMP SYSTEM
T3S = LED DAYTIME RUNNING LIGHT
T3U = FRONT FOGLAMP
T4F = HEADLAMPS,XENON
T79 = FOR REAR FOGLAMPS
T95 = DIRECTIONAL HEADLAMPS (ADAPTIVE FORWARD LIGHTING)
TQ5 = FOR INTELLIGENT HIGH BEAM
TR0 = LAMP INTERIOR,ROOF,REAR,COURTESY AND DUAL READING
TR7 = HEADLAMP LEVELLING,AUTOMATIC
TS6 = BRAKE LAMP,HIGH LEVEL,CENTER
TSQ = LAMP INTERIOR DELUXE
TTW = FOR AUTOMATIC HEADLAMPS WITH TUNNEL DETECTION
*** Bodycar: ***
B9K = PLATE DOOR SILL COVER
D75 = HANDLE,ASSY.,OUTSIDE
E3C = COVER
MDE = FOR CHROME WINDOW SURROUND MOULDING
VG2 = PROTECTION WAX,DELETE
*** Interior: ***
01A = BLACK SEAT TRIM
1AB = TRIM COLOUR DOOR PANEL BLACK
2HS = MOULDING DOOR INTERIOR,RUTHENIUM METALLIC / LIQUID PALLADIUM
4AA = BLACK INTERIOR TRIM
A64 = FOR 40/60 SPLIT SEAT
B75 = COVER,ASSY.,LUGGAGE
C1R = MOULDING INSTRUMENT PANEL INTERIOR, JET BLACK
DVN = INSTRUMENT CLUSTER,BLACK,TRANSLUCENT RING
EBZ = TRIM SEAT CLOTH, RIBBON
FCS = TRIM, LEATHER MONDIAL
KC5 = RECEPTACLE,ELECTRICAL ACCESSORY(12V)
LHD = LEFT HAND DRIVE
N34 = WHEEL,ASSY.,STEERING,THREE SPOKES,LEATHER
U18 = SPEEDOMETER,ASSY.,K.P.H
V8U = INSTRUMENT PANEL CENTRE, LIQUID PALLADIUM / RUTHENIUM METALLIC
VRG = OPEL / VAUXHALL SPECIFICATION - COCKPIT
VRK = OPEL / VAUXHALL SPECIFICATION - ROOF TRIM
*** Safety: ***
A69 = RESTRAINT SEAT BELT TENSIONER, FRT
AJF = HEAD RESTRAINT,FRONT SEAT,ACTIVE
AQP = USED WITH CENTRE REAR HEAD RESTRAINT
AYC = FOR DRIVER,PASSENGER,SIDE AND CURTAIN AIR BAG
C99 = PASSENGER AIRBAG DISABLE SWITCH
E = ACTIVE MANUAL BELTS, AIRBAGS, DRIVER AND PASSENGER FRONT, FRONT SEAT SIDE, ROOF SIDE
FX3 = ELECTRONIC STABILITY PROGRAM
J67 = FOR USE WITH 15" BRAKE SYSTEM
KB5 = HILL-START ASSISTANT
U04 = HORN,SINGLE NOTE
UH0 = SEAT BELT WARNING,LH
UH1 = SEAT BELT WARNING,RH
ULS = LOCK CONTROL, STEERING COLUMN
*** Multimedia: ***
TTX = RADIO EQUIPMENT AUXILIARY CONNECTOR LINE IN
U65 = SPEAKER,7
U68 = INFORMATION COMPUTER
UC3 = STEERING WHEEL, RADIO AND PHONE CONTROLS
UDC = FOR MONOCHROMATIC DOT MATRIX DRIVER INFORMATION CENTRE
UDN = COLOUR INFORMATION DISPLAY 7" WVGA
UHR = RADIO NAVI 650
UPH = WITH WIRELESS INTERFACE,SHORT RANGE,VOICE REC
US3 = ANTENNA DIVERSITY
WGC = EQUIPMENT RECEIVING UNIT,GPS
*** Heating and air conditioning: ***
CJ2 = CLIMATE CONTROL
KCL = HEATER DUCT,REAR PASSENGER 2ND POSITION
*** Equipment and comfort: ***
A51 = FRONT BUCKET SEAT
AG5 = FRONT SEAT,RH,HEIGHT ADJUSTER,MANUAL
AH3 = FRONT SEAT,DRIVER,MANUAL ADJUSTING
CE1 = WIPER,FRONT,PULSE SYSTEM
DBU = FRONT FLOOR CONSOLE WITH SLIDING ARMREST
K33 = CRUISE CONTROL
N37 = STEERING COLUMN, ADJUSTABLE, REACH AND RAKE
NJ1 = POWER STEERING, NON-VARIABLE RATIO, ELECTRIC STANDARD RACK TRAVEL
*** Electrical system: ***
K3K = BATTERY,50AH
K60 = ALTERNATOR,100AMP
richkr74
Dakujem velmi pekne.
