Re: Informácie obiashnuté vo VIN čísle
				Napsal: 09 pro 2015, 18:39
				od Phrz
				jojo bude trosku vic priskrcenej aby splnil euro 6
				Napsal: 15 črc 2019, 21:21
				od richkr74
				Zdravim ,mohol by mi niekto dekodovat toto VIN?  W0LPE6EC0E1106602. Niekedy davno to tu niekto robil,dekodovali mi tu Zafiru B ale na vedlajsom fore Astra H - Zafira B forum. Viete to urobit aj z Astrou J 103kw 1.4 . Dakujem
				Napsal: 15 črc 2019, 21:55
				od Xzar
				Code =	Description
*** General information: ***
AUY =	BREAKPOINT IDENT CONTROL
AXJ =	VEHICLE TYPE, PASSENGER CAR
CR7 =	FOR HUNGARY
FPV =	BREAKPOINT IDENT CONTROL
GAR =	EXTERIOR PAINT, SEE MODEL CATALOGUE FOREWORD PAINT CHART
PE =	EQUIPMENT LEVEL: COSMO / INNOVATION
V83 =	VEHICLE STATEMENT - ECE ORGANIZATION
VD1 =	EUROPE EQUIPMENT
VRH =	OPEL / VAUXHALL SPECIFICATION - STEERING COLUMN
XL8 =	FOR 433 MHZ FREQUENCY
ZP5 =	SEATING ARRANGEMENT 5 PASSENGERS
*** Drive (engine, transmission): ***
F82 =	FINAL DRIVE RATIO 3.23
LUJ =	A14NET[LUJ] PETROL ENGINE
MH8 =	6T40 AUTOMATIC TRANSMISSION
MM1 =	USED WITH AUTOMATIC TRANSMISSION
NE9 =	EMISSION SYSTEM EEC 09
V48 =	COOLANT,MAXIMUM PROTECTION
*** Suspension and wheels: ***
GNA =	CHASSIS EQUIPMENT, FRONT STRUT ASSEMBLY
GNG =	REAR AXLE, TORSION BEAM AND WATT LINKAGE
PXS =	WHEEL,ALUMINUM,17 X 7J
QAJ =	TYRES,215/50R17-91V
RU5 =	FOR SPACE SAVER WHEEL
VRL =	OPEL / VAUXHALL SPECIFICATION - FRONT HORIZONTIAL SUSPENSION
VRM =	OPEL / VAUXHALL SPECIFICATION - FRONT VERTICAL SUSPENSION
VRN =	OPEL / VAUXHALL SPECIFICATION - REAR SUSPENSION
VRR =	OPEL / VAUXHALL SPECIFICATION - TYRES AND WHEELS
*** Glass and mirrors: ***
AEF =	POWER WINDOWS, EXPRESS UP/DOWN
AER =	ELECTRICALLY OPERATED WINDOWS,REAR
AKN =	GLASS,TINTED
AKW =	WINDSCREEN,TINTED
AXG =	FOR ONE TOUCH WINDOW
C25 =	TAIL GATE WIPER AND WASHER
D6I =	VISOR,SUN,WITH ILLUMINATED MIRROR
DD8 =	FOR LIGHT SENSITIVE INTERIOR MIRROR
DP6 =	MIRROR HOUSING, PAINTED
DWE =	USED WITH MANUAL FOLDING MIRROR
*** Lighting: ***
C95 =	LAMP,ASSY,ROOF,WITH DUAL READING LAMP
C9B =	LAMP INTERIOR, AMBIENT, DOOR
C9D =	LAMP INTERIOR, AMBIENT, CONSOLE
CE4 =	HEADLAMP WASHER
T39 =	LAMPS,TURN SIGNAL,AUXILARY
T3N =	FOR DAYTIME RUNNING LAMP SYSTEM
T3S =	LED DAYTIME RUNNING LIGHT
T3U =	FRONT FOGLAMP
T4F =	HEADLAMPS,XENON
T79 =	FOR REAR FOGLAMPS
T95 =	DIRECTIONAL HEADLAMPS (ADAPTIVE FORWARD LIGHTING)
TQ5 =	FOR INTELLIGENT HIGH BEAM
TR0 =	LAMP INTERIOR,ROOF,REAR,COURTESY AND DUAL READING
TR7 =	HEADLAMP LEVELLING,AUTOMATIC
TS6 =	BRAKE LAMP,HIGH LEVEL,CENTER
TSQ =	LAMP INTERIOR DELUXE
TTW =	FOR AUTOMATIC HEADLAMPS WITH TUNNEL DETECTION
*** Bodycar: ***
B9K =	PLATE DOOR SILL COVER
D75 =	HANDLE,ASSY.,OUTSIDE
E3C =	COVER
MDE =	FOR CHROME WINDOW SURROUND MOULDING
VG2 =	PROTECTION WAX,DELETE
*** Interior: ***
01A =	BLACK SEAT TRIM
1AB =	TRIM COLOUR DOOR PANEL BLACK
2HS =	MOULDING DOOR INTERIOR,RUTHENIUM METALLIC / LIQUID PALLADIUM
4AA =	BLACK INTERIOR TRIM
A64 =	FOR 40/60 SPLIT SEAT
B75 =	COVER,ASSY.,LUGGAGE
C1R =	MOULDING INSTRUMENT PANEL INTERIOR, JET BLACK
DVN =	INSTRUMENT CLUSTER,BLACK,TRANSLUCENT RING
EBZ =	TRIM SEAT CLOTH, RIBBON
FCS =	TRIM, LEATHER MONDIAL
KC5 =	RECEPTACLE,ELECTRICAL ACCESSORY(12V)
LHD =	LEFT HAND DRIVE
N34 =	WHEEL,ASSY.,STEERING,THREE SPOKES,LEATHER
U18 =	SPEEDOMETER,ASSY.,K.P.H
V8U =	INSTRUMENT PANEL CENTRE, LIQUID PALLADIUM / RUTHENIUM METALLIC
VRG =	OPEL / VAUXHALL SPECIFICATION - COCKPIT
VRK =	OPEL / VAUXHALL SPECIFICATION - ROOF TRIM
*** Safety: ***
A69 =	RESTRAINT SEAT BELT TENSIONER, FRT
AJF =	HEAD RESTRAINT,FRONT SEAT,ACTIVE
AQP =	USED WITH CENTRE REAR HEAD RESTRAINT
AYC =	FOR DRIVER,PASSENGER,SIDE AND CURTAIN AIR BAG
C99 =	PASSENGER AIRBAG DISABLE SWITCH
E =	ACTIVE MANUAL BELTS, AIRBAGS, DRIVER AND PASSENGER FRONT, FRONT SEAT SIDE, ROOF SIDE
FX3 =	ELECTRONIC STABILITY PROGRAM
J67 =	FOR USE WITH 15" BRAKE SYSTEM
KB5 =	HILL-START ASSISTANT
U04 =	HORN,SINGLE NOTE
UH0 =	SEAT BELT WARNING,LH
UH1 =	SEAT BELT WARNING,RH
ULS =	LOCK CONTROL, STEERING COLUMN
*** Multimedia: ***
TTX =	RADIO EQUIPMENT AUXILIARY CONNECTOR LINE IN
U65 =	SPEAKER,7
U68 =	INFORMATION COMPUTER
UC3 =	STEERING WHEEL, RADIO AND PHONE CONTROLS
UDC =	FOR MONOCHROMATIC DOT MATRIX DRIVER INFORMATION CENTRE
UDN =	COLOUR INFORMATION DISPLAY 7" WVGA
UHR =	RADIO NAVI 650
UPH =	WITH WIRELESS INTERFACE,SHORT RANGE,VOICE REC
US3 =	ANTENNA DIVERSITY
WGC =	EQUIPMENT RECEIVING UNIT,GPS
*** Heating and air conditioning: ***
CJ2 =	CLIMATE CONTROL
KCL =	HEATER DUCT,REAR PASSENGER 2ND POSITION
*** Equipment and comfort: ***
A51 =	FRONT BUCKET SEAT
AG5 =	FRONT SEAT,RH,HEIGHT ADJUSTER,MANUAL
AH3 =	FRONT SEAT,DRIVER,MANUAL ADJUSTING
CE1 =	WIPER,FRONT,PULSE SYSTEM
DBU =	FRONT FLOOR CONSOLE WITH SLIDING ARMREST
K33 =	CRUISE CONTROL
N37 =	STEERING COLUMN, ADJUSTABLE, REACH AND RAKE
NJ1 =	POWER STEERING, NON-VARIABLE RATIO, ELECTRIC STANDARD RACK TRAVEL
*** Electrical system: ***
K3K =	BATTERY,50AH
K60 =	ALTERNATOR,100AMP
				Napsal: 23 črc 2019, 20:39
				od richkr74
				Dakujem velmi pekne.
